TwinTurbo.NET: Nissan 300ZX forum - mine was 17psi when fuel pressure started to drop (n/m)
toykoz32
on June 02, 2013 at 3:18 PM
Hmm. I have run up to 30.5psi of boost, so say 75psi
posted by Ash's Z
on June 02, 2013 at 01:29 PM
Introducing a heavy duty hi-amp FPC made from OEM.
DVDBURN (MD)
20:06:38 06/01/13
What do you suggest to avoid the issue others are having
Evan_Wright (Ca)
20:36:44 06/01/13
Last time I talked to Gary.. We were talking about the
KongZTT GT28RS MD
20:40:40 06/01/13
The pumps only run at full speed for short bursts when
Ash's Z
21:04:58 06/01/13
not true -- folks will have issues whenever you have
The Devils Z
21:47:14 06/01/13
I've been running it in my personal Z for 50K miles now
Ash's Z
23:44:09 06/01/13
There is no reason why anyone should take the power wire of
The Devils Z
12:58:31 06/02/13
? The pumps always receive (+) power when the fuel
Ash's Z
13:26:52 06/02/13
your response doesn't explain to me why to use the OEM
The Devils Z
15:23:36 06/02/13
I'm not saying that beefing up the wiring would have any
Ash's Z
00:02:57 06/03/13
I can't speak to your feelings and I am not speaking
The Devils Z
00:50:14 06/03/13
I understand. I just think that the few cases that there
Ash's Z
12:57:33 06/03/13
the power circuit isn't really the issue
aliaZ
00:47:09 06/03/13
If you have the right size power wire, it doesn't matter
The Devils Z
01:03:48 06/03/13
The ground is just as important as the (+) feed line.
Ash's Z
10:01:13 06/03/13
the current must have a return path
aliaZ
10:28:39 06/03/13
Ironically enough, the electrons actually come from the (-)
Ash's Z
12:53:54 06/03/13
Whaaa?
KongZTT GT28RS MD
05:13:33 06/04/13
also, the specialty Z setup isn't necessarily better.
aliaZ
00:51:22 06/03/13
The stock wiring & connectors are only capable of supplying
sparkie
12:01:15 06/02/13
I saw the same thing . . and needed the same thing (n/m)
toykoz32
13:16:40 06/02/13
Ash's Z
13:29:19 06/02/13
mine was 17psi when fuel pressure started to drop (n/m) -
toykoz32
15:18:48 06/02/13
Something else was wrong then.
Ash's Z
15:10:44 06/03/13
Your wrong Ash, we about burned up the stock wiring harness
DarkZide
22:27:30 06/02/13
I suspect there was a different issue that caused this.
DVDBURN (MD)
00:30:31 06/02/13
Wow Gary!
KongZTT GT28RS MD
20:37:54 06/01/13
Thats awesome, Gary. Will it be available without the switch
ZXoltan
20:38:56 06/01/13
I'll probably end up making most of them that way.
DVDBURN (MD)
01:28:26 06/02/13
Looks great, Gary. :)
Ash's Z
21:10:43 06/01/13
Thanks Ash.
DVDBURN (MD)
01:13:56 06/02/13
That power supply I gave you goes up to 500amps :) (n/m)
KongZTT GT28RS MD
03:34:22 06/02/13
No no. The load bank is something else. (n/m)
DVDBURN (MD)
07:25:08 06/02/13
My mistake :) (n/m)
KongZTT GT28RS MD
08:05:45 06/02/13
The circuit traces will fail before you even get close to
Ash's Z
13:25:18 06/02/13
Re: The circuit traces will fail before you even get close to
DVDBURN (MD)
22:50:03 06/02/13
will still need to address the factory wiring harness issue
The Devils Z
21:40:15 06/01/13
I will agree with you, but only in certain applications.. >>
Ash's Z
00:06:39 06/02/13
What do the stock tt pumps pull?
michaell32 (FL)
04:36:30 06/02/13
The Deatschwerks DW300 pumps are pretty efficient too
maglito
16:28:53 06/02/13
I have one of those laying around.
michaell32 (FL)
20:45:47 06/02/13
I like them, I have two in my fuel tank right now. (n/m)
maglito
10:16:08 06/03/13
very cool (n/m)
Madhatter10-6
22:05:41 06/01/13
Very cool!!
Bigwill837
22:06:26 06/01/13
I am scared of you (n/m)
22:07:58 06/01/13
Ha! He's like the automotive Dr Frankenstein...
ForceFedTT (SoCal)
01:10:59 06/02/13
Wait till you see how he works in person..
KongZTT GT28RS MD
03:39:15 06/02/13
My fuel pump i always on hi, that's now my map sensor input
TTZ2NV(EPTmotorsports)
01:52:45 06/02/13
AThe stealth 340 should be able to handle more than 700
KongZTT GT28RS MD
04:07:14 06/02/13
Acording to Greg d , aeromotives pulls too many amps for the
ztunerz
08:07:05 06/02/13
The main reason for this FPC mod is to eliminate the FPC as
DVDBURN (MD)
08:52:55 06/02/13
What size fuses would you recommend? (n/m)
toykoz32
13:21:20 06/02/13
Depends on the max continuous current of the fuel pump.
DVDBURN (MD)
23:22:34 06/02/13
this is true -- the documentation is in their manaul
The Devils Z
09:15:15 06/03/13
Simple = better :) (n/m)
ztunerz
08:08:29 06/02/13
If you need 60mm fans I think I have a few dozen laying
09:01:03 06/02/13
I just threw a bunch out he could've had too. No one seemed
ZXoltan
10:46:29 06/02/13
Well done Gary! (n/m)
TheTwinZ (Peru)
13:56:20 06/02/13
Cool! All it needs is a washable filter on the fan (n/m)
Ashman2k2
20:00:31 06/02/13
